No, not that droop, this will take more than a little blue pill.
When I bought this Argo, an 85 I/C K17, I thought the clearance between the tyres and the mudwings (fenders / body ?) was minimal as you can't get fingers in without touching both tyre and body (20" tyres). Anyhow, today I popped the top off to check things out and make winch mounts etc.
What I've found is the part of the lower tub above the wheels droops down towards the outer edge, quite substantially, about (a guess here) 1.5". I'm thinking make a frame from 1" x 1/8" sq tube that fits all around the outside edge between top and bottom tub (it looks like it will go in) and then fit cross members from the same material. The angle that goes side to side across the rear of the fuel tank is bent down at both ends so get rid of that and replace with the 1" square.
The rear of the front seat sat on this angle and the front of the seat on the fuel tank !! So the obvious answer here is to make two cross members tied together to support the whole seat. I can get another cross member at the rear of the tub (between inner and outer) or perhaps two inside the tub to support a rear seat. The front end can have one around the front of the engine tied into the winch mount.
If I do this and weld all cross members to outer frame this should lift and support the edges of the lower tub, I can put verticals down to the frame in various places that should give it quite a bit of strength.
The big questions are, (A) is this a common thing and (B) is there an easier / accepted way of solving it, (C) when the top is off should the lower tub above the tyres be perfectly horizontal, IE flat?
I shall not give up on this now, I've become quite attached to it already although I think it was owned by the village idiot in a previous life (the front seat cover was stapled to the fuel tank !!!, the alternator is tensioned with a spring to the frame)
One more little thing, what's the best way to fill small holes in the body (pop rivet holes etc)?
Cheers guys, answers greatly appreciated as always and sorry to take your time up.
