As said on other posts, I took the top off the new Argo (new to me). I found a wonderful assortment of interesting oddities such as seat upholstery stapled to the fuel tank, alternator welded to the front deck support and tensioned by a spring and jamming it on the wheel well (see pics). It's good to see how the other half work
Anyway, I found it was suffering terrible wheel well droop (see pics with straight edge across them) so I tried to rectify one side to start with. Clamped a length of steel down the outer edge, Jacked it straight with high lifts and got the bend hot with hot air gun. Worked lovely, just got the other side to do then fit a bracing frame to stop it happening again (someone mentioned this method in another thread, thanks whoever it was (can't remember and can't go and look while posting this ))
I found all the chains loose to the extent they almost touch the cross members running through the frame, funny thing is they don't look or feel worn ??? They look almost new and the seller did say it had new chains recently ?? Too many links from new possibly ?? How many should there be, anyone know ? On a brighter note, all but the front axles are splined and the brakes are hydraulic, there doesn't appear to be any cracks in the frame, But one pan is rotten and the others are badly repaired.
All in all it's not too bad. I'm not going to do a rebuild at the moment as I have only run it about 10 minutes. I shall do what's required to get it usable then give it a few hours use, pull it back in and then do a better job on it. At the moment it's still an unknown quantity. And it's taking up production space in the factory, need to get rid of the quad etc first.
Oh, and I still have to get rid of that awful snot green paint
