I've got a 2002 Argo Response that isn't equipped with a skid pan. Being that its over 11 years old (124 hours on the clock) and in good shape, should I worry about damaging the belly swamp riding?
Are skid pans a necessity?
I think it all depends on how much you use it and the type of terrain you are going over. There are many early machines that did not have skid plates. Some are still in use as well. On the other hand I am on my second skid plate for my machine (I am the second owner, 2002 conquest). I use my machine over a lot of tree stumps and rough hard ground.
The skid plate will protect your machine.Even if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
Originally posted by Southarkrob View PostI am a complete noob when it comes to these atvs...I am going to be looking at a 2005 response...can somebody post a pic of what the skid pan looks like??Even if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
Originally posted by HarryT View PostI've got a 2002 Argo Response that isn't equipped with a skid pan. Being that its over 11 years old (124 hours on the clock) and in good shape, should I worry about damaging the belly swamp riding?
Since you are looking for a cross section of opinions here is mine,on my early machines I have "Holed the Tub"without a skid plate,on my last fourish machines I opted out of a skid plate,the reason I extensively use my machine in water and felt that to drill the tub full of holes to add one could wait,if I happen to puncture the tub I will repair it and silicone and then put a plate on over it,I run in Northern Ontario all of the time and have not holed one in 25 plus years,mostly run trails and forest access roads so not to much to bother it,the tub is pretty robust after all it is backed by a pretty hefty floor plate inside.JMO NCT
