Does anyone know the dimensions of a 2002 Argo 8x8 Response? The current model is a couple cm too wide for me at 154cm. I see that the previous model is significantly lighter so it may be a bit smaller too. My limit is 150cm so a new 6x6 would just fit at 147cm, but there are a few used older ones on sale with very few (<200) hours on the clock.
8x8 Response 2002 dimensions?
60" would have been too wide, but I took measures when I was inspecting a 2003 8x8 Response this morning. I found it to be 295 x 145cm. Which just about matches the current Frontier 8x8 at 119x58". The current Avenger is 119x60". I suspect the 2 extra inches on the recent models come from the bigger 25" tires which probably also are a little wider.Last edited by phel; 04-17-2013, 03:04 PM.
