hey everyone I recently put Adair tracks on and they are amazing. The only problem is the Argo pulls to three right pretty bad. I looked at my chains and the right side is very tight. My left side has the normal play in it. Any ideas to look at. Also i used a rachet strap to connect the tracks they have play also. They are the same length so I figured the left would be tight add well. Running4psi in all 8. Any ideas 316-201-7828 Ty. Thank you
argo response chain tight with tracks
But would that cause the over tightness of the chains on the right side? Is there a chain adjuster? Can the tracks be to tight? I have play in the middle of the tracks. and both tracks are the same. IDK why one side would be tight and the others is normal. and they were the same before the tracks. its tight from top to bottom. Please help Need to fic before memorial THank you. I understand the tire diam for the pulling though Thank you for the response
I know this is for argo plastic tracks but the application should be the same for both track systems. Hope this helps. http://www.argoadventure.com/uploade...RACK%20KIT.pdf
