Has anyone heard of the web site www.rollerchain4less? It's a division of Belarus Tractor International and the contact information is in Milwaukee, WI. They have 50-2 chain in 10 ft lengths for $40. The tinsel strength is 13,200 lbs. Wondering if this would work on my 87 I/C. It's a lot cheaper then Diamond or Tsubaki chain and I will only put on about 20-30 hours a year once I finish my rebuild. Any thought would help. Thanks in advance.
50-2 roller chain
Tensile strength is not what you look for its working load normal 5/8 pitch double wide has a working load of about 2400 lbs Diamond and tsubaki exceed this what is the working load of this chain? is it a full roller or are the rollers split? split rollers are flat plate curled into a circle but not welded they crack apart under prolonged load.
