I was messing with the Argo tonight. I was adjusting the throttle linkage. I carefully checked to make sure it was in neutral before I started it. I was standing next to it so I could adjust the linkage while it was running. Bad idea! Turns out that it wasn't "quite" in neutral. The engine started and took off like a bat out of hell. What a helpless feeling. It hit my 1969 coot and cracked the ABS lips where the two halves bolt together. The coot is built like a tank. They are all metal and HEAVY. The Coot barely moved forward but it's time to make some repairs to the Argo.
It's time to build a bumper. I've seen a few on here made out of angle iron. It looks like the builder cut small triangles then bent and welded. I would like to do the same. Will someone please give me some tips on how they got theirs to turn out so nice I would really appreciate it.
