Buffalo Bearings part numbers?
  • Buffalo Bearings part numbers?
    I have a 2002 Response that needs four outer axle bearings and eight seals.
    I called Buffalo Bearings and they ask me to order by the part numbers.
    I haven't removed my axles yet so I was hoping someone could tell me which bearings and seals to order.
    PS: I searched but only found Maxx part numbers.
    Thanks.
    should be same for a conquest..
    Its the same as my 2000 Conquest.
    Axle Bearing Information
    Outer Bearing (stock): Part#101-35 = UC206-20
    Inner Bearing (stock): Part#101-41 = UCX05-16
    Seal (stock): Part#102-14 = CR12361 1.25x1.75x0.188
    Seal (stock): Part#102-15 = CR12379 1.25x1.874x0.25
    You can call Buffalo Bearings, they have the bearings and seals. 1-800-669-8019
      Thanks, I had the Argo part numbers but the salesperson ask me for their part number. Thanks, again.
        Can someone share the prices of these items? Thank you.
          Outer Bearing (stock): Part#101-35 = UC206-20 UC206-20 1 1/4" Insert Bearing Insert Bearing, normal duty, wide inner ring, set screw locking, anti-rotation device $8.96
          Inner Bearing (stock): Part#101-41 = UCX05-16 UCX05-16 1" Insert Bearing (Medium Duty), Set Screw Locking $14.45
          Seals were considerably cheaper from Argo Adventure | Argo Parts $2.35 each
          Just went through ordering all this for my Vanguard 2.
            The outer bearings are now $11.70 and the seals are a little over $9.00. They are out of seals right now. The I lady I talked to was very pleasant.
            Now I'll be calling Argo Adventure for the seals and gaskets.
            Thanks for the help. Hope to be floating soon.
              My bearings came in today. The part number is MAX UC206-20R3. $12.55 each Great service from Buffalo Bearings and Argo Adventure.
                hi ,
                Harryt The uc206-20r3 description ??? Is it a 62mm od spherical outer and 1 1/4 id R3=triple seal ,, set screw or locking collar ??
                cheers tomo
                  UC is the locking collar type. The set screw type are HC. 206 is a 62mm spherical O.D. 20 is the I.D. in 1/16's of an inch IE. 20/16" = 1 1/4". R3 is the designation for triple seals.
                  Joe.
                    Oops, I found a better price at the Big Bearing Store. Results for Insert Bearings:UC200 Series
                    UC206-20 1-1/4" Set Screw Locking Insert Bearing Small OD
                    1-1/4" Insert bearing with wide inner ring and two set screws. Spherical OD and greasable.
                    Price: $8.48
                    I guess it pays to shop around.
                      I shop at Big Bearing or Prime Bearing.
                        Price: $8.48
                        The Big Bearing Store is where I shop. Better prices and lots more in stock. I left Buffalo Bearing long ago.
                          hi ,
                          remember to all that both argo and max have been using triple sealed OUTER bearings for some time .
                          As with everything there are cheap Chinese copies [if u like changing bearings a lot ]
                          It does appear if the price is around the 30 dollar for a Japanese NTN
                          REL207-104D1LLS 72MMOD 1 1/4 ID SPHERICAL OUTER ,greaseable, triple lip ,locking collar
                          REL206-104D1LLJS 62MM OD 1 1/4 ID spherical outer greaseable triple lip locking collar
                          uc207-104LLS 72mm 1 1/4 id spherical outer greaseable triple lip set screw
                          UC206-104LLS 62mm 1 1/4 id spherical outer greaseable triple lip set screw
                          tomo
                            These are Fushan bearings made in China. My Argo only got a little over 100 hours on the factory axle bearings, how many hours can I hope for with these (Chinese) bearings?
                              hi
                              typically most OEM donot use high quality bearings ,similar to there bearing housings eg the pressed metal housings on max agh agh .........
                              The question of longevity of bearing is a good one, hrs of life ???
                              U need some one who has owned a machine since new for a long time .
                              tomo
