Are the rotor brake 10T srockets replacable? I ask because I've seen them sold with the sprocket already attached to the rotor. Thank you.
Avenger rotor brake sprockets...
Depending on which Avenger you have, there is a part number for the sprocket, those are held on with 5 or 6 1/4" bolts. If yours are replaceable you'll need to find the manual that lists them.sigpic
Get ahold of mark at 2d max in fair banks. Maybe he can weld a new sprocket onto the rotor? If it is all 6 tooth spline what does it matter... One peice or two peice , it is all on the same shaft.Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
ATV = Alaska Terain Vehicle
Originally posted by ARGOJIM View PostDepending on which Avenger you have, there is a part number for the sprocket, those are held on with 5 or 6 1/4" bolts. If yours are replaceable you'll need to find the manual that lists them.
Any place known that might have any of these ten tooth sprockets?Stand for the Flag. Kneel for the Cross.
