Alright so I started tearing the argo apart to fix or replace my right mid axle. I removed the chains on that side, pulled the bolts from the outer flange as well as the inner flange. I only found one set screw on the outer most part of the sprocket, I removed it. Now my problem is, Im stuck. The inner flange seems to be stuck to the inner bearing and wont come off. Anyone have any ideas on how to get the inner flange and bearing off of the axle?
Also, once I get the bearing and flange off, the axle should just slide out right through the sprocket and outer bearing, correct?
And one more thing, Once I finally get it apart and get my axle fixed, What should I replace and what should I make sure to do to make sure it still floats?
