Hello. My right hand turning slowly failed on our last ride, and I didn't take brake fluid with me, of which I've added to the tool box. Too late, but its there now.
I've added fluid but the caliper didn't respond.
Anyhoo... I followed the service manual regarding the bleeding procedure. The caliper is mounted to the brake rotor bolt, the reservoir is filled with DOT 5. When we follow the procedure to bleed the caliper it never squeezes the quarter-inch spacer inserted into the caliper to represent the rotor's thickness.
We've done the procedure over and over, but the caliper never squeezes, nor does the fluid pressure build up enough to squeeze the caliper.
Well, I'm stumped. Any advice is greatly appreciated.
