I saw this while doing my search on the Argo. I know I want to get tracks on my Argo when I will buy one. But is those dual wheels kit sure look like they will be able to do the same job as a set of tracks or maybe not? I am pretty sure they will make the argo a better swimmer than a set of tracks. What do you guys think of these?
Dual wheels kit or tracks?
I do not think it would replace tracks
It would not replace tracks but you could put some mega wide ones on and stay on top of the fluffiest powder snow but Super Tracks should be enough .
Duellies and tracks would look mean
I was thinking about this the other day.
I could run my 24" Frontiers, and double them up with the 22" Runamucks. That way I would be running around on the bigger tires, until I start to sink in the mud/muskeg. Then all tires would come into play.
The problem is that I can't think of too many places where this would be needed
. Might just be more trouble than it's worth. Maintaining tire pressures in 8 tires (12 with a trailer) is bad enough, 16 would be hell (20 with the trailer
Not to mention getting access to the inner tires
Cool idea though, and duelly tracks would look just plain MEAN
duels are bad but tracks are mean .1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
R.I.P sage rogers 4 11 09 .
16 Wheeler
How is this for a setup, I'm sure some of you guys will recognize it, it's called a "Bushswamper", they also made a "Grizzly" version with 24 wheels. The chain drive is submersed in oil, it runs down the middle and is only about 8" wide. It's the only place you can get high centered on. I know the foreman who ran the shop where they produced them for about 20 years or so, he said they were virtually unstopable. They could put a whole moose on it and run it through the swamps with no problem.
How did it steer?
Do you know what they used as a transmission?Originally posted by Bw6 View PostHow is this for a setup, I'm sure some of you guys will recognize it, it's called a "Bushswamper", they also made a "Grizzly" version with 24 wheels. The chain drive is submersed in oil, it runs down the middle and is only about 8" wide. It's the only place you can get high centered on. I know the foreman who ran the shop where they produced them for about 20 years or so, he said they were virtually unstopable. They could put a whole moose on it and run it through the swamps with no problem.Why do we waste tax money on bridges and roads when we can all just drive AATVs
There's a brochure of that Bush Swamper in the literature section: http://www.6x6world.com/forums/brand...h-swamper.html
It says "unique non-skid steering"
I have the 18 inch super tracks on my bigfoot and they seem to do a great job. It floated over 18-20 inches of fresh powder snow like it was only 3 inches deep. The ice cleats are great too. they give you just that little bit of extra grip you need to make the machine unstopable.
More Bushswamper Pics
I think from the pic's you can see the steering mechanism. It has 2 identical gearboxes with f-n-r, so you can do zero radius turns. The way it steers is by turning the steering wheel, there is a linkage that opens one of the driver clutches, and at the same time activates the brake on that side.
How is that “unique non-skid steering”?
Originally posted by Bw6 View PostI think from the pic's you can see the steering mechanism. It has 2 identical gearboxes with f-n-r, so you can do zero radius turns. The way it steers is by turning the steering wheel, there is a linkage that opens one of the driver clutches, and at the same time activates the brake on that side.What I think you are describing is a type of skid steering one would find in a some types of Bobcats or Bulldozers .Originally posted by Mike View PostThere's a brochure of that Bush Swamper in the literature section: http://www.6x6world.com/forums/brand...h-swamper.html
If that is the case the brochure is misleading stating “unique non-skid steering”Why do we waste tax money on bridges and roads when we can all just drive AATVs
Just have to slow down a little going between marrow trees.. Hehehe. Seriously, hard on axles
