Having problems shifting the transmission. The owners manual says this is a clutch issue and the repair should be done by a dealer as special tools are required. I am 4 hrs from a dealer. Any input regarding clutch slider replacement and tools needed will be a great help.
Argo Avenger 2006 Clutch Nylon Sliders
Which transmission? (I think avengers had 2 choices in 2006?)
What sort of problem?
Clutch maintenance/repair is pretty easy* once you've seen it all done. Rock Doctor posted videos so that we can see it done. Search for clutch videos.
* Okay, there are some cases, such as real bad corrosion, that can make any job extremely frustrating and make a guy daydream of thermite.
Both the primary and secondary clutch are very easy to remove and basically come off as one piece. I bet you could ship the to the dealer and have them rebuild. I did this when I had an Avenger to have my clutch weights changed for high altitude.Originally posted by 8x8 View PostHaving problems shifting the transmission. The owners manual says this is a clutch issue and the repair should be done by a dealer as special tools are required. I am 4 hrs from a dealer. Any input regarding clutch slider replacement and tools needed will be a great help.
