My conquest runs great. But no matter how long I run it, it won't stay run ing at idle unless I play with the throttle to keep it revved up a bit. When I have it at an idle that keeps it running, it shifts fine and stays run ing strong. But if I give it gas and just let off the throttle when it reaches idle it dies. I am not sure if I ned to just adjust the throttle cable, or if I need to adjust the idle. My thought is the cable needs adjusted. There is a lot of play at the end of the cable. I do have a new cable if it would just be better to change it. Any ideas please let me know. Thanks guys.
Throttle cable adjustment or idle adjustment?
The idle screw is on the radiator side of the carb., if you want to remove some slack for quicker response ( after idle adjustment) loosen the screw on muffler side holding the cable and slide back the cable housing slightly NOT changing the idle.sigpic
Originally posted by ARGOJIM View PostThe idle screw is on the radiator side of the carb., if you want to remove some slack for quicker response ( after idle adjustment) loosen the screw on muffler side holding the cable and slide back the cable housing slightly NOT changing the idle.
The conquest has a idle adjustment screw. When sitting in the machine, hood off, look at the base of the carb, just about dead center, thats the mixture adjustment, dont touch it. To the right and up about three inches is the idle adjustment screw. you have to get low to see it, and you should be able to get a screw driver on it fairly easy. Turn it to the right until it idles without holding the throttle. If you send me your email, i'll sent you the repair manual for the FD620D in PDF format.
Originally posted by Paul219 View PostThe conquest has a idle adjustment screw. When sitting in the machine, hood off, look at the base of the carb, just about dead center, thats the mixture adjustment, dont touch it. To the right and up about three inches is the idle adjustment screw. you have to get low to see it, and you should be able to get a screw driver on it fairly easy. Turn it to the right until it idles without holding the throttle. If you send me your email, i'll sent you the repair manual for the FD620D in PDF format.
