Trying to change the grease bearing zircs on inside front axels of 98 Conquest. These do not have a way to attach a wrench and I don't want to strip them out Any suggestions on an effective way to remove.
Changing inside grease zircs
Originally posted by Dan67 View PostI just ended up ordering new stamped flanges with 90 degree grease zergs from my argo dealer and replacing them so they are easier to get to. Only about $5 each.
That's the way to go , they are press fit fittings.sigpic
My 650HD has press fittings, several have popped and I have tried lock-tite, they still pop. My local Mechanic sugested tapping hoses to the fittings and bringing the flex hoses to a block so all of them can be greased at one location. This sounds like a good idea for the inside of the machine. ( sick of hanging upside down and backwards to try and grease the inside front bearings). I will let you know how it works.
Steve
Works great on heavy equipment. I never thought of trying it on anything else. Definitely keep us posted on this one.Originally posted by steve mcd View PostMy 650HD has press fittings, several have popped and I have tried lock-tite, they still pop. My local Mechanic sugested tapping hoses to the fittings and bringing the flex hoses to a block so all of them can be greased at one location. This sounds like a good idea for the inside of the machine. ( sick of hanging upside down and backwards to try a nd grease the inside front bearings). I will let you know how it works.
Steve
Just be careful that the hoses don't get plugged up with dirt or old grease, then you won't be able to get any grease in at all.. I agree though with the idea cuz they can be a pain to get to..Originally posted by steve mcd View PostMy 650HD has press fittings, several have popped and I have tried lock-tite, they still pop. My local Mechanic sugested tapping hoses to the fittings and bringing the flex hoses to a block so all of them can be greased at one location. This sounds like a good idea for the inside of the machine. ( sick of hanging upside down and backwards to try and grease the inside front bearings). I will let you know how it works.
Steve
