I wouldn't even consider the higher geared transmission for any application. The lower gears will make this machine a powerhorse. I recently had my Frontier switched from the 2.2 to the 3.3 transmission and its like an altogether different machine, it stays in the power band for the engine, as a result the engine doesn't overheat and spit and backfire like it did before, and the machine turns infinitely better. Even though my machine has the old style transmission, the lower gearing allows this thing to perform very similar to an Admiral transmission.
I think the dealer did you a favor in this case. The application you described will necessitate the lower gearing. I've only heard good things about that dealer over the years.
