Hi there all, just bought and argo and this is my first post to this forum. It is a 6x6 IC 1986 with a 17 hp Kohler engine. I keep seeing models like conquest, bigfoot and vanguard. How do I know which model is mine for ordering parts. I plan on trying to make a snow plow for it as my argo dealer rep here told me I cant get parts like windshields, canopies and plows for it anymore. Thanks for the help in advance. Plan on picking your brains more over the coming months. Demo
What model is my Argo?
Demo, 6 I/C is the model name for parts look under the K models but order off serial number range.
Top is available special order in black only and non returnable, windshield would have to be checked on.
You could order the factory snowplow but would need to make mounting brackets as you should not have the bearing extensions and frame was probably not made for them, the plow mount brackets mount to the extension housings.sigpic
Where can I order these accessories from? As my argo dealer is of no help to me. Also if I'm trying to order aftermarket parts and they don't say anything about IC models, is there another model that is close? Seems all the parts are for those models previously mentioned but never seen any that states their for an IC model.I demolish my bridges behind me, that way there's no choice but to move forward...
Hi demo, welcome. I think your argo might be a Magnum.If you contact ODG/Argo with your serial number they will tell you what you want to know. I need to mention that tying your machine down by the winch is not really recommended. There are many stories about hitting potholes and soft shoulders and ditches where the winch let go. Tying to the axles on each end could save problems. Also tying over the machine with cargo straps is going to make a guy unhappy when the body sags and the tracks or tires rub. good luck with your new toy.
I bought a 72" moose utility plow today and the atv bracket. Going to fabricate it to fit like SiliconTi did in one of his posts. Also, never considered the safety factor with the winch before. I have two heavy cargo straps on the back, guess I was just being lazy up front. I'll add two more to the winch and trailer at the front. As for accessories, I'm just going to fabricate everythig I need I think. Much easier and faster. Plus more fun and gratifying. Thanks everyone for the help, I'll keep you all posted with the updates and pictures. DemoOriginally posted by philipatmaxfour View PostHi demo, welcome. I think your argo might be a Magnum.If you contact ODG/Argo with your serial number they will tell you what you want to know. I need to mention that tying your machine down by the winch is not really recommended. There are many stories about hitting potholes and soft shoulders and ditches where the winch let go. Tying to the axles on each end could save problems. Also tying over the machine with cargo straps is going to make a guy unhappy when the body sags and the tracks or tires rub. good luck with your new toy.I demolish my bridges behind me, that way there's no choice but to move forward...
I am not sure if it is a good idea to tie your Argo down by the axels. This can damage the axels if it is a bumpy ride.
I found it best to secure some large square deck posts on the trailer. One in front of each front tire and one in back of each back tire, then run a strap across the top to keep it from bouncing up. Works well, Argo never moves an inch. Just don't torque the strap down super tight or you will get the droop like everyone is talking about.
