Are all the splined argo sprockets interchangeable? Mine is a 93 Vanguard. I have one (center axle) that the chain, which is new, is hopping on. Also i've emailed Richard over at route6x6 about a new or used one and havent got a reply. If anyone has one new or used, or knows a good source, I'd appreciate the info.
Argo sprocket info please?
Chances are that if one is worn out, then all of them should be looked at.
Some guys will pull all sprockets when they are showing too much wear, and swap them to the other side of the Argo. This will be like installing "new" sprockets, the chains will now be working on the unworn side of the sprocket teeth. You will still be working the worn side of the teeth when in reverse, but most guys don't spend all that much time in reverse. This will allow you to get a little more time out of your sprockets.
I have never tried doing this, but some guys seem to think it works fine.
I did that with brake rotor/sprockets and idler shafts while they were out. Hard to see any wear, but cleaned and up close you could just see a little. Minimal wear due to compulsive cleaning and lubing.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
