Outer Bearing
  • Outer Bearing
    I am planning to replace the outer bearing I have now with something that will keep more water out.
    I have an older Argo and it has a 3 hole flange. I found these for $35 her in Canada
    I just wondered if anyone had uses these kind of bearings?
    Or is there a way to keep the water from coming in between the flange and bearing?
    I used a good silicone and I have been leak free for the last 2 months
      hi ,
      I have used 4 bolt cast iron housings .Installed on outside of tub .
      Best installation is to use hollow flanged dowl pin [locates housing to chassis ,does not break the silicon sealant joint ,housing has zero movement ]
      dowl pin size od 14mm id 10.25mm ,use either a 10mm bolt or a 3/8 bolt
      use triple seal bearings
      grease every use
      tomo
