conquest tranmission
pulled the transmission out of the conquest reverse is going out ,bolts are out case spit but not coming apart ,do you have to pull the plugs out and take the clips off ,don't look like that has to happen or do you just work it apart ,any tips would me great
Tags: None
You really kinda need 3 hands, remove both snap rings and shim on cover side and while prying up on the cover (evenly, or in 2 opposite positions), tap the output shaft with a soft hammer.
You are most likely fighting the 2 large bearings on the output shaft.sigpic
There is a procedure for removing the cover in the Argo service manual provided by Argo adventure. Just google Argo service manual. It has a step by step tear down and assembly procedures with pictures. For the transmissions without the jacking bolt holes in the cover you need to tap the input shaft using a soft rubber mallet. As mentioned by ARGOJIM, keep a close eye on the output shaft bearings to ensure the cover is coming out evenly.
Dave
