So I went out for a short ride yesterday to try to get the fresh gas into the system and ended up with a different problem. The brakes were working good until it got all warmed up and then the left side seems to have tightened up. Madr it difficult to turn right because the left side was braking too. Is this a simple adjustment? How do you adjust them? The machine only has 110 hrs so I wouldn't think it would be bad calipers yet?
hydraulic brake adjustment
Does the new machine have sticks or a t-bar? If it's a t-bar I'd suspect the stops have been bent holding the brake partially on, common problem with the Avengers and makes it impossible to bleed them.
If that is the problem bend them back straight, they are square tabs in the t-bar frame with holes for the plungers to come through, then adjustments to plungers can be made if needed.sigpic
Originally posted by Rock Doctor View PostIf you have too much brake fluid in your master cylinder, it will expand when it gets hot, and not have enough room, this could cause the brake to drag.
