Probably need a theoretical physicist for this one.
Been mulling this question over for months now, and still come up with the same answer.
On an Argo you shouldn't hold a steering brake on to make a sweeping turn, but rather go round a curve in a series of "jerks", IE, brake on, brake off, brake on , etc, etc.
What I fail to understand is the physics of this, as in. Given a known curve, at a known speed and a known weight it takes the same amount of energy to steer round it no matter if you "curve" round it or go in a series of "jerks". The energy absorbed by the inside brakes is converted to heat, and this is a given amount relative to speed and radius.
Therefore, if you go round in a series of jerks the amount of heat generated by bringing one side to a frequent halt should equal the amount generated by feathering the brakes .
So gents, any thoughts on this, has anyone actually tested this with a thermometer?
Feel free to blow my theories out of the water, always more than willing to listen to someone better educated (it's how you learn)
