Hello everyone,
I recently had the bright idea (or not so bright) to build a custom receiver for the rear hitch on my 1997 Bigfoot. This was to incorporate both retaining the current hitch ball and mounting an aluminum rear carrier.
This basically meant welding up an extended hitch that fit into the stock receiver and allowed the 2" ball hitch to be received into the end of that, and had a 15" vertical section with another receiver to allow the carrier to slide into.
It worked great... until I realized if I put any weight into the carrier I would end up flexing/twisting and/or breaking the frame because of the extra leverage....it's not strong enough.....I didn't even realize the stock hitch assembly is really quite weak, I can flex the rear frame with it just by pushing down on it with my foot only. I don't remember my early 90's 8-wheeler having this weak of a hitch.
Has anyone ever "beefed up" the stock hitch/frame to accommodate leverage.....if so how?
Welding and plastic don't exactly mix too well.....
Or is this something that should be avoided, and just stick with pulling a tub trailer for extra cargo capacity?
Thank you all for any thoughts, ideas and opinions.
