Hello,
I recently replaced the old two stroke kohler in my 1970's Argo with a 23 hp Vanguard. Conversion has gone fine and overall I am happy with the results. I wanted to get some advice/opinions on my exhaust system. I took it for a ride tonight and after shutting it down realized the hood was pretty warm. Warm enough that I was a bit concerned.
The muffler is standard from B&S. I wrapped it with heat wrap and then installed a heat shield over the top. Right now it has ventilation on each side and the hood was off when I was running it. I do not have an air intake running towards the engine. The heat shield is pretty close to the hood. Ranges from 1-4 inches.
I posted some pictures to let you know what I am talking about. Do the hoods heat up quite a bit on you machines? Almost hot to the touch when touching it for about 5 seconds? By the way it was 80 degrees out while I was driving it.
I am thinking my options are to add a heat shield to the bottom of the muffler as well to direct some more heat out the side. Possibly another shield on top of the existing, or making my hood a little bigger to allow for more room between the shield and hood. Just wanted to see what you were experiencing first.
Thanks
Thanks
