Great site.. chock full of realtime info. I don't ask many questions but here is an idea i am working on. Did not want to carry a spare battery so i went ahead and removed the stock battery from my 2007 avenger efi and noticed that a full size yellow Optima D34/deep cycle /starting 750cca/120min reserve battery will slide in perfectly and the battery cover goes right back in place...Should make winching effortless too...also noticed that the stock strap that holds the battery down was cheesy at best so now i use a 1" rafting cam strap and that works great. My thought was to run a cable to the back and install a plug for the trolling motor near the motor mount. This way i can charge my troling battery when i ride. I usually ride and camp in for no less than 3 days at a time and always fear my battery going dead so in place of the spare battery i bought a Yamaha 1000 watt generator to recharge the battery in the event i leave something on or maybe a small short somewhere. If my starter and engine hold up i should be in good shape. Other things i've added include a perimeter alarm with pager, Horn, Tachometer/hour meter, bilge pump indicator light, battery discharge indicator light, spare brake cable, spare throttle cable, brake fan shutoff switch and indicator light, moved throttle ajustment knob forward for easy access, installed seat hinges, installed rear floor holdown knob [no more bouncing floor], handle bar mounted garmin gps 60csx, and intake door from Shocky model. All these thing really improved the ability to read my Argo..getting back home is the name of the game...Right! Now my question is...Will my altenator be able to charge the larger battery??
Tracmaster
Tracmaster
