Hey Guy's I am planning my Tub Support and wanted some feed back before I get the angle grinder out.
I have an older 70's Argo 8x8. The tub has some droop so I need to put some support in to clear the tires. I also replaced the motor and need to make some room in the engine bay. I can run it with the hood off the air breather sticks up a too far to keep the hood on.
I am in the planning stage at this point. So far the plan is to put c channel between the upper and lower tub. This will give me the extra space I need and keep the droop out. I want to tie the c channel into the frame with some square tube.
I am concerned about weight and keeping some flex in the Tub. I also want to keep it so I can remove the entire support.
Has anyone done this yet? Any words of wisdom. I have seen square tube used to support the tub but haven't come across anyone using it to split the upper and lower portions to give more clearance between them.
When I am done I want to have hitch receivers front and back for winch/boat motor.
Here is a picture of what I am thinking
Orange is the tub, Black is the new supports, gray is the frame
