I have a 1994 Argo Vanguard. Ive had it for a few months and I am pretty impressed by the machine. It runs pretty good and goes places I never imagined it could. I have a couple questions for you guys with more experience with them. I can't change gears without shutting it off. It seems the primary clutch engages at a very low rpm. I have to start it in the gear I want and hold the levers back because it will start rolling slowly as soon as I start it. I assume this isnt normal. Also is it normal to feel the chains rub on the floor? They seem to rub a bit durning tight turning manuvers. Plus it is a noisy machine lol . I'm not exactly sure what noises are normal and what ones aren't. Thanks in advance for the input.
Couple questions about my Argo Vanguard
Glad you are enjoying your new machine. You are correct, that is not normal. I've not experienced this with mine. But the first thing thing that comes to mind is high idle. Does it seem to be running at a high idle? My machine runs at a very low idle.
As far as the chain slap. That is normal. Although you still should check for stretched chains.
rck90 check that you have some play in the cable, engine won't idle if the cable is taught and spray all the linkages, you may also want to loosen the 2 bolts holding the governor plate and twist it one way and the other ( just the slop in the bolt holes). Some had a high and low limit screw on gov. plate. It only takes a hair on Kawasaki's to cause high idle.sigpic
Does it have an Argo 125-56 belt on it?Originally posted by montess85 View PostIt seems to be idling low. Ill have to see if I can adjust it lower. Maybe a carb rebuilt is in order.sigpic
Rck90 if the engine is racing you may need to adjust the governor, the carb should be clean and known functioning correctly. There are two tabs that possibly need adjusting, the one bolted to the head which gives both bottom and top end limits and the circular governor linkage that can create a forced idle.
Check the B&S manuals or links on the home page, you're to far to guess.sigpic
