I am about to embark on an Argo rebuild project. But first a little background; 2004 (I think) Argo Bigfoot. Bough it used, ran it for a bit then had an issue with one of the axles. Tore everything apart and then the house flooded. I live on a River and the Argo was purchased mostly to get to and from the house in times of a flood. Water ended up getting in the tub and with the flood, the Argo was the least of the worries. The tub ended up sitting for an extended period of time and (in case you haven't guessed) rust took over and ruined everything. Chains, axles, bearings, sprockets and bolts... all seized and rusted. I had previously pulled the engine/transmission so it was unaffected. I have finally gotten back to this project. The plan is to basically rebuild the entire Argo. Pull everything (and I mean everything) apart, remove the frame, have everything sandblasted and then refinished and finally rebuild and put it all back together. Most of the moving parts, axles, chains, tensioners, gears, ect are going to have to be purchased new as the old ones are beyond salvage.
With the flood last week and having to kayak to and from the house, it is time to get this Argo put back together and use it for it's intended purpose. I'm a little overwhelmed and probably a little over my head so any help, tips, advise, info... whatever really is greatly appreciated! I'll get some pictures up tomorrow in the daylight.
