I've researched this thread but didn't find any answers. My 2006 Bigfoot is pulling to the right so bad I have to make abrupt corrections every 5 feet. After the brakes get warm I get a severe squealing on the right side. I just replaced the master cylinders, rods, and hold-brake cable. I put Dot 5 in both cylinders and bled em. I know it's in my brakes. I can't have them deer hearing that squealing this weekend.
Brake Problems
Did you check tire size/air pressure on both sides. As well check your idler chain tension. When you changed you fluid did you make sure there was nothing left in the lines....may have been some moisture there??????Even if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
Tires and chain tension are good, brake fan is working. I have a pasture behind my house and can only make it twice around before the right brake gets hot and starts squealing. Once it gets hot it pulls to the right. There is dot 5 residue on the rotor/caliper, but can't see that causing the brake grabbing. Any ideas on what would cause the right brake to grab? Does anyone know of a dealer close to Albany Georgia?
Check that the 2 tabs on the tbar where the plungers go through are not bent forward, the stops should barely contact the tabs. If the are hitting adjust them, if tabs are bent straighten them first, the check the rod adjustment (you should be able to spin them with your fingers fairly easily).sigpic
I agree, folks should consider overhauling these calipers unless they are really rusted and munged up. I've never taken apart a simpler caliper. I would go so far as calling these perfect for handing to a neighborhood kid as a first tinkering project in John's garage. The dangerous part, same for all calipers, is when you use a shot of air to force the pistons out; this can absolutely destroy any piece of human anatomy. Do not get between the piston and anything when you are doing that. I usually stuff a rag in the gap so things don't get dinged up too.
I'm pretty sure Rock Doctor has posted a video of how it's done too.
The o-ring kit is cheap from an Argo dealer.
I didn't realize the simplicity of rebuilding the calipers, I do now though. My biggest hurdle was I had to get it ready for deer season tomorrow. It's 100% now after 2 new brake cylinders, new steering rods, throttle cable, new right caliper, new pads. I cant' say enough good stuff about Ed and his crew from Argo-Adventure, they got me my parts in a day, (not to mention the excellent tech support). Dang these things are fun when they are running right. I already can tell I need a stronger motor. Let the fun begin.
Originally posted by gkp View Post... I already can tell I need a stronger motor. ...
It's a disease I tell ya.
Before you give in to that project make sure you've cleaned and tuned the CVT. You might have all you need already. (I did say need. Now, want...?)
Oh, forgot to mention that there are many threads describing this in the transmissions forum. Search for "Rock Doctor Clutch mod".
Okay, so I'm editing again. Changed the search string as the first one had too many hits. (tried my own advice out) And probably CVT talk should jump to another post in the transmissions forum.
Here's one thread with some descriptionLast edited by JohnF; 10-17-2014, 06:14 PM.
