Just picked up my first 6x6. everything is in pretty good shape overall. It was originally owned by the Canadian dept of transportation. I bought it from the second owner. When I got it last week, it had the wrong drive belt installed( wide polaris snowmobile belt). The prior owner would start it in gear and turn it off to switch gears , or stall it when braking. He had the original worn belt that was marked 125-25. This matched the parts manual I have for the 6x6. I ordered and installed the new belt. I can now start in neutral and shift into gear, however, when braking it still doesn't disengage wich also prevents me from shifting fwd to rev. The Tecumseh 16 idles down fast and the primary clutch fully opens. The driven clutch closes. It looks as if the belt is too short. This is a bit confusing as everything on the machine looks to be original, and the original belt is the same size as the new one. I have lubed both clutches and they appear to be working as they should. I will note that at idle, the belt sits about 1/2-3/4 down below the edge of the driven clutch. Any thoughts would be great. Thanks.
Argo 1982 HT 6x6 clutch or drive belt
Did you try cleaning the faces on your clutches? What about idle speed. With the machine shut off , how do your belt sit in the clutches? They need to be slow before youy change gear. Sometimes it helps to put the machine in reverse before shifting to forward.Even if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
1982 Argo belt
Clutches are clean and no oil or grease. Idle will go all the way down and can even stall out and it will remain engaged. Idle speed is not the issue. I can press on the belt before a start to open up the driven clutch and put some slack in the belt, and start and it will shift fine. It just seems like the belt is too tight. How far up on the driven clutch should the belt sit? When the primary is fully open(engine slow or off) the belt sits in the closed , driven clutch , about 3/4 of an inch from the top. What I mean by this is that the top of the belt to the top of the driven clutch edge is about 3/4 of an inch. It would seem that the belt should run up higher on the driven clutch , meaning the belt should be longer.
82 HT belt
Belt goes all theway to the bottom of the driven clutch when reved. Just started it and observed. Looks like it still touches the belt on the sides even at top engine speed. I think i may have found out the issue. The driven pully says "bombardier made in canada 414-2009-003. Is this the correct clutch? Possible its been replaced?
There were 3 different clutch setups and 2 different belts on the Tec.'s so you'll need to know what clutch is on the engine.
The 125-25 belt was used on the Salisbury 780 set up like what was on mine, the belt is only 1-3/16.
I'd guess the driven was replaced, if it is the same diameter you may be able to pull a shim or 2 and narrow it up to the 1-3/16, other wise you need to match the clutches.sigpic
82 argo belt
What do you mean be "pull a shim" ? Also I don't need to make the driven clutch narrower, if anything it seems like it needs to be kept open. When stopped the drive cluch is fully opened and the driven clutch is closed hard against the sides of the belt.
hi
Agree with all others .
The clutches need to be identified . MATCHED PAIR ONLY
[NON MATCHING CLUTCHES CAN BE USED BUT ONLY BY A PERSON WHO CAN SET THEM UP, WITH THE CORRECT BELT ]
A factory ...belt and clutches... are exactly that, matched set components .
Find part no`s of clutches or post pictures
tomo
Originally posted by dfgtye View PostWhat do you mean be "pull a shim" ? Also I don't need to make the driven clutch narrower, if anything it seems like it needs to be kept open. When stopped the drive cluch is fully opened and the driven clutch is closed hard against the sides of the belt.
Sorry misunderstood the description, thinking the belt had slack but sitting low in the driven.sigpic
82 Argo Belt
OK. The clutches are not a matched set. The front is the stock salsbury 780. The driven is a bombardier 414-2009 003. They line up perfectly and work fine. My guess is that the diameter of the driven is about 1 in greater than that of the stock salsbury. If I can limit the closing of the driven the standard belt will work. How/can a clutch be shimmed open? Is the shim just a bushing on the shaft. Other option of course is to vary the belt size, but a larger belt will reduce the speed and will be a hit or miss guess at the size.
So any thoughts? Shim and how. Or any way to measure for the correct belt size
Different question. Anyone know what the part number on there driven clutch is. I can find salsbury 780 driven clutches online but with a couple different part numbers stamped on them. The manual says 125-38 (152004). These aren't the numbers I'm seeing. Or is a 780 a 780. I'm seeing the 780 with a 1 in bore & a 1/4 keyway and a 8.5 inch outside diameter. Rather match the clutch than guess at belts. Thanks for the help.
hi
An Argo specialist will respond .
the particular combination u require may well be specific to argo I donot no.
In general terms
Mean while 780 drive is very common 3/4 ,7/8, 1 ,1 1/8 bores
The 700 series inclusive of 770 ,780 ,790 ..driven....[ transmission] different diameters 790 fastest etc 770 the slowest
There are torque and speed sensitive and then there are 3 different generations
Somebody may verify the Bombadear is ok to use but without being there to eyeball it ,it is a difficult scenario .
Some things that people donot think about is the angle of the clutches and belt must also work together .
tomo
Does anyone know the bore size of the clutch on the argo. It looks to me to be a 1 1/8 in, but when i look for comet/salsbury 780 driven clutches online, all i find is 3/4 , 7/8, and 1 bores nothing in 1 1/8. My manual doesn't give the dimensions, and the part number 1520044 or 125-38 returns no good info for me. Thanks.
