Replacing all the chains, inner and outer bearings on my 1998 Conquest. When tearing it down I noticed that several of the outer bearing set screws had came loose and scared up the shaft. When I put it back together should I Loctite the bearing set screws? Also should I address the area where the shaft is damaged?
Thanks!!
Thanks!!
