So I recently bought an 07 Avenger. I went through the machine and replaced a bunch of bearings an axle and did the usual maintenance thing. It runs really well and does it's job. However, it started doing something strange when the weather turned bitter cold -25C. First it would start fine, run for 30 secs or so then stop. When I hit the key again it would take a bit of convincing from the throttle to go, then it's fine. Yesterday I had it out and it took a considerable amount of cranking to get it started, but like before when warm it runs like a champ. I'm leaning towards an O2 sensor, I stopped to stretch my legs and the diagnostic light came on. I got a code 31, but the light never came back on after I read the code. I know from years of automotive work that computer controlled cars operate on a pre set program until the O2 sensor reaches temp, thus having heated sensors reduces warm up time, but I would assume that it would still run on pre set parameters for the first few mins.
Question 2 does anyone else have over cooling problems with these EFI engines? I changed the stat just out of instinct, but I actually had to tape a plastic bag the to air intake so it would run at normal temp. Do these engines have constant direct drive fan or are they clutched? This is also another reason I'm leaning towards an O2 sensor, if it's been running cold it'll be all gummed up.
Thanks
Thanks
