Wow, I cant seam to catch a break! I have had my argo a total of 6 weeks now, taken it out once on a 50 mile glacier trek, and stripped the teeth off of the right side brake disk/drive sprocket. And after about 2 weeks waiting for the parts to show up I started troubleshooting the charging problem and pulling the disks off. In the process I found out I have the exact same problem with the left side output shaft on my transmission that M350 had with his. It appears that the shaft was worn down but the bearing looks fine, like it had been replaced, or just did not wear like the shaft did. Has anyone else ever had the same problem? I am hoping this is not all that common, but it is odd that it is the exact same story in two differernt machines.
Run a corner of a file across the shaft. If it cuts it , it's too soft.
