Axles Vanguard
  • Axles Vanguard
    Newbie here,
    Where to buy axles part number 810-75
    I just pulled mine to replace bearings and noticed some wear around.
    There is a thread here on how to fix that issue. I did it on all six of mine when I replaced the bearings on my machine. I think the thread is a how to.
      Looks as if the bearing has been riding loose on the axle.
      The 810-75 axle has been discontinued, the HD axle is a direct replacement with the added benefit of the heavier flange and will work with existing bearings.
        I think it had been riding loose. When looking at service manual it says lock bearing to shaft. It just slid right out.
        I'm replacing 6 bearings. All new seals.
