My conquest runs/starts great for me with one exception. When I drive it for a while (say a few miles) and then stop and let it idle, it will idle fine for about a minute and then it will flood out and die. I can then smell gas fumes (not a dangerous amount). It will start back up but only if I give it full throttle. It will blow some black smoke out a bit because it is flooded, but runs great under power. It seems to only do it at higher altitudes and after it has been worked some.
If I start it in my driveway at lower elevation and cold, it will idle fine.
I am wondering if my float needs to be adjusted a bit lower? I did remember adjusting it a bit higher when I was troubleshooting it for a stuck solenoid when I first got it.
Am I barking up the right tree here? I am not really worried about it not starting, but it is some times again in the a$$ if I need it to idle for me w/o giving it some throttle to burn off the excess. Any thoughts?
