winch wiring question
  • winch wiring question
    I just moved my winch switch from where it was to on the left handle bar(not throttle). I used a brand new warn winch switch that I had laying around. my question is, if the switch was for a 2500 lbs winch will it work under load for an argo winch? (not sure of the size but it's bigger then 2500)?
    If it's just a two way toggle that operates a switching relay you are good to go. The relay handles the load.
      it's the kind of switch that when you press it in/out it powers the winch then when you let it go it stops. it's the switch that comes with warn winches and mounts on 4 wheeler handle bars
        Just three wires going to it? If so its controlling the relay and the load is not through the switch.
          yup only three wires going to it. thanks a bunch
