Is it possible to drill my factory wheels and axle flanges for greasing on a 2004?
winter tune-up for my conquest
You mean outside right ?Originally posted by Dan67 View PostYes the kit has you putting the set screw to the inside of the argo.
So this is the same thing for the mid axles?
Also, the water can go between the shaft and the bearing, do you put something there like green loctite or right stuff ?
I'm going to try the electrical tape trick that I read about on this site (help with credits) on my current build. I'm planning on using Scotch #88 it's heavier than 33+.Originally posted by capri302 View PostAlso, the water can go between the shaft and the bearing, do you put something there like green loctite or right stuff ?sigpic
