When i am out on the lake, i always have to pull the left lever back to go straight and follow a trail. besides being annoying it slows me down and i barely go fast enough as it is. i noticed when i had them jacked off the ground, the left side doesnt seem to turn like the right one does. It starts turning only after i pull back the right lever. Is this the way it was supposed to be? I appreciate any help and or advice.
Both my early Vanguards pull to the right
Don't let the way it acts when it's jacked up in the air mislead you. With an open differential, typically one side will turn with no load. For your issues on the ground, I would start by checking the tire pressure. If all of your tires are at the same pressure and you are still having the same issue, measure the circumference of the tires and inflate them so that they are all equal circumference and ignore the pressure. Or, swap them from one side to the other and see if the problem still persists.
i run tracks, but i know some tires have more air than others, 1 was flat. Its hard to get at the air valves when covered in snow and ice. i need to replace some of the tires so i will be removing the tracks after the snow is gone. i though there might be an adjustment or my tranny was having issues. thanks for the reply. its all a learning experience.
No, the number of links in the chain don't determine the relative drive-to-driven sprocket speeds. Sprocket size determines this. If you have one more link in one chain the chain adjusters will likely be in different positions to take up chain slack, but that has no bearing on how fast the wheel is turning.Originally posted by fredfox View PostIf one drive chain is a link longer it will also do this.
Double check the circumference of your tires as suggested.Last edited by hydromike; 03-26-2015, 02:16 PM.sigpic
Originally posted by hydromike View PostNo, the number of links in the chain don't determine the relative drive-to-driven sprocket speeds. Sprocket size determines this. If you have one more link in one chain the chain adjusters will likely be in different positions to take up chain slack, but that has no bearing on how fast the wheel is turning.
Steve these guys bring up good points, your machines have manual brakes and if one is to tight (dragging) it will pull.
Try to jack up the machine with the sticks forward/ in neutral and see if one side has more drag than the other, if so loosen the brakes on tight side.
If these items don't cure it perhaps you're holding the stick back slightly, manual brakes like to be held to the firewall. Or maybe your weight off to 1 side is causing it to overdrive the other side, try sitting in the middle with the machine empty.sigpic
Jim you trying to say i am fat? lol j/k i have adjusted the brakes. still lots of pads. reading manuals i have learned how to adjust them properly, do not forget the follow up nut!vibration moves bolts. seems not to be pulling as much. i need to build a jack to lift the whole argo. project coming. thanks all. i have 6 new tires to put on as well.
