I have a late 70's model T base Argo that has started to leak water into the machine from the front right wheel bearing. I am looking at replacing the bearings, can anyone tell me how I locate part numbers and also any tips on where to order parts from for these older machines. Serial number is T4021, not sure if that helps.
leak in front right wheel bearing
argo parts
Its easy to locate parts from dealers or often from other members on this site. Where are you.Originally posted by gotrippedoff View PostI have a late 70's model T base Argo that has started to leak water into the machine from the front right wheel bearing. I am looking at replacing the bearings, can anyone tell me how I locate part numbers and also any tips on where to order parts from for these older machines. Serial number is T4021, not sure if that helps.
By the way is that ever a nice looking machine.
I am in Wisconsin. The closest dealer is in Beaver Dam. Thank you for the compliment, I had to stick a good chunk of money into it to get it where it is today. Just wish I would have been able to put it in the water before I replaced all of the chains on it. After I thought it was ready to go, I drove it into the water and started to take on a lot of water. Thank goodness for the bilge pump I put in
Also, is it a good idea to replace the drive axels as well since I will be replacing the bearings? Also does anyone know if it is possible to get splined axels for these instead of the roller pinned ones that are currently on it, or would that be a lot of work to modify?
I would like to put tracks on it someday and I am afraid the smaller axels and roller pins would not stand up to the torque that tracks would put on them. Thanks
