Had to replace the front left I believe you would call it drive Shaft on my Argo. The outer bearing was worn out for too long which forced me to also replace that shaft. I put it all back together and the idler chain on the replaced shaft is much tighter. Is this normal due to the new sprocket? Shouldn't cause any problems?
Idler chain tension?
