Yes, accidentally. I was exploring the possibility of using a bilge blower which fit in a hole in the firewall of an Argo Frontier. My plan was to blow cool air into the hood to limit overheating. Inadvertantly, I placed the blower in backwards and it blew warm air into the passenger compartment. Then I figured a 3 way switch would allow me to reverse the flow of air, which it did.
It worked pretty well for several years until the blower gave out, and I never replaced it. In Texas where I live, we really want to get rid of the heat more than directing it into the passenger area, but I could see where you guys up north might want to capture the heat. Later on I added a grill over the exhaust manifold, and small hood scoops to get more air flow going on, that worked pretty well too.
Has anyone ever put in closeable louvers into the engine compartment for adding heat to the passenger compartment?
Thoughts?
I always end up removing some of the windows in the standard soft top before I go very far. My avenger never goes much over an indicated 170* but it sure blows heat into the cabin with a roof on. Good luck with your new toy.
Let me clear that up a bit. I want to add heat via louvers through the plastic engine cover, beside the shifter somewhere, that i can open or close. You are correct I am up north and the $600 price tag is a little steep for a glorified heat box. Just wondering if anyone has done it, or had a couple pics of how they did it? I suspect that the engine throws ample heat, even in cold conditions. If the fresh air intake is high and i mount these louvers somewhat lower. I should still get the engine cooling i need plus be able to get myself some heat in the cab.
sigpic Peace and Solitude of the worlds forests can be crushed by 1 broken part....
[QUOTE=treetop62;186377]Has anyone ever put in closeable louvers into the engine compartment for adding heat to the passenger compartment?
Thoughts?[/QUOTE)
Do you have any type of top on your unit now? A top is the best way to hold heat in the cabin,even without cutting up the firewall.
