Top for my Avenger done. Went with 1/2 top on this argo had a full top on my last one.
Avenger Top Done
I went with half top because when trailer is full of moose meat and you need to load more into argo, you don't have to muscle it through back door. Bad back. Much easier to load.Attached Files
IMG_1161.jpgIMG_1162.jpgIMG_1164.jpgI have to plug Harbor Freight 7 ton pipe bender, worked fantastic when putting top together. Found that you need to go 1/2 inch undersize on die to get a good clean bend on pipe. The 2" brush rake in the front of the machine is one continuous piece to back, with one support welded in at front of door. Thanks Harbor Frt.
