Can someone tell me is there a way to tighten idler chains ??
Bigfoot slack on idler chains
Look at bottom of front of transmission by motor there is a nut to be loosened. Now at the rear of the transmission the is a bolt on each side that if you turn will raise the tranny and tighten the idler chains. There is also a bracket that supports the upper hull on top of the tranny that needs to be loosend before tightening the idlers. Once adjusted tighten top bracket and large nut on tranny.
Ok thanks for advice ! I didn´t know that the transmission can be moved by bolts. I have exchanged both chains but it didn´t help so i checked out the manual and the slack on idler chains is abaut 3mm and i have almost an inch so i was thinking that there have to be a way to get them tighten... I am not very good with this stuff but in here,the only way is to do it by yourself cause there isn't any dealers for argos in here. This forum is pretty much the only place for me to get even some information abaut argos from experienced drivers.
Here,go to page 8 (of PDF,pg 5 of actual book) and study the assy. You want to loosen nuts (3) # 22 and use bolt # 39 to raise/lower the power pack. Hope this link works and helps ya,
