First argo avenger 700 bought a month ago new
Getting ready for a alaskan adventurer soon
Then 3 days ago came across one here in the village that was a steal
Bought it for a back up rig and now we going to get it ready to go in pairs
Hood missing
Hard top.
Tracks
In good shape by looking at it
Noticed front left inner bearing destroyed, no ballbearing
Starting taking the shaft out. Inner race stuck on there like its welded to it
Cut the race off with a dremal cut off wheel
Then i said to my self. If ones bad. Im ganna replace all
On one side had to cut bearing off with dremal
Then Ill work on the otherside next.
So far this sucks
Argo needs a better system here. Not just a HD upgrade
Im thinking a roller inner bearing type with thrust bearing in one
Bearing housing instead of these flanges
The forces are to high for this
Enough of the beaching
Tranny jack shafts. One is flopping around Drivers side
This calls for the experienced fellows that can guide me in the right way of doing these
I was told by Argo rep Ed to take tranny out is the easiest way
I will atemp this task when the weather gets better
Raining in the Arctic so early
I will leave tracks off unless theres snow
Take wheel extentions off due to long leverage
Forces that seams to be the destroyer of these cheesy bearing housings
Also noticed the setscrew walking the shaft , digging a ditch that has to be filed down before you can slide the front bearing off. Right off the flats huh.
This tells me they need to drill 3/32 hole on 4 sides of the shaft and add more setscrews
To much forces to this size bearing. HD or not
Tony
Hood missing
Hard top.
Tracks
So far this sucks
Tony
