Finally take the new argo out to the trap line. We need a 10x14 wood shed skidded to a different place. After jacking it up and putting logs under it, I go to pull the shed with the argo's rear hitch. Needless to say that's bent now, sigh. Turn the machine around to use the front mounted dealer installed winch and brush guard. Put a little suck on the line and "snap", what was that? look around and don't see anything noticeable. Resume the suck and "snap", this happens 2 more times and I finally notice the brush guard is moving when i put a suck on the winch. After further inspection I see that the 4 rivets at the front of the argo that connect the plastic to the frame have popped, thus the snaps i heard. Does the winch mount flex that much that the rivets should pop? I doubt it.
Get shed moved with some creative engineering, and decide I need a break better go for a cruise. After covering approx 16km I notice the passenger side track has a lot of slack in it. Get out check the pressures, all are good except 1 (the tire I have a tube in) feel air rushing out while inflating the tire and find a small cut in sidewall of tire. This is the second time that apparently gravel has cut the side wall of my tires.(both times on a lease road, no sticks to be found) stick a plug in and we are off and running but these tires are JUNK. Set all the pressures the same and still notice track is a bit loose for my liking. I was told when I bought the machine that track stretch will happen. Fine, but why is only 1 stretched? drivers side is fine. So can I pull the spacer piece out of the passenger side and leave it in on the drivers?
Drive a little further and start hearing a ticking sound( fan motor on a housing type of racket). Check engine bay, all looks normal, sound if from my feet. After careful inspection I notice the 1 Teflon puck on the chain tensioner is near wore through and the other side is like brand new plus some oil. I try to adjust this tensioner and no way, is this thing budging. What would cause this?
After our eventful day we are heading home, argo limped us back to the vehicle and off we go. Drive approx 1 hr out of my 3 hour drive and pull over to check straps, pee, etc and notice my hood on my argo is gone. I know the hood latches were done up as I did it. But would those popped rivets have anything to do with that plastic flexing and allowing the hood to evacuate?
Note: I do tow it backwards.
I'm going to crawl in my cave and escape daylight for a couple days. The argo is scheduled to go to the dealer this week so here is hoping warranty covers most/all of this. I should also mention that I have a 2015 750 HDI (camo) with 350km on argo and 40 hrs. I haven't even greased my bearing yet.
Fustrated.
Fustrated.
