Hi everyone,
Looking for some guidance as i move forward in fixing up the 2 machines i just bought.
First up, the 750HDi has the newer transmission with the simple forward reverse shifting and the hi-low on the dash. the Hi-Lo seems to do absolutely nothings so i will need to check for a linkage that may be disconnected.
The HDi seems to clunk a bit when you steer in either direction either while moving or while sitting and will not spin in a circle on the spot like the Avenger does it will just do tight donuts. Is this normal?
The HDi is also noticeably slower than the EFI even thought the HDi has the bigger engine. is this normal due to the transmission? perhaps due to the hi-low not working?
Also, at some point these have each bent or broken an axle out in the field and were limped back rubbing the tire through the tub. Is there any way to patch this? I have thought about adding black teflon used on the bottom of jet boats to patch it and protect against further wear accepting the fact they will likely never float again.
Finally, (for now) it looks like the HDi rear wheels are higher than the rest, i assumed it was bent axles but they dont seem to wobble, they seem to just be slightly higher than the rest yet still more or less balanced.
thanks for any help you can provide. LOTS of work to do!
