So i managed to wiggle my 750HDI into low range by pulling out the firewall panel and forcing the linkage (obviously adjustment is needed) however, i got stuck on a couple logs and found that the belt slips at the clutch before the tires spin out, similarly i can't spin on the spot from a dead stop and have to be moving first.
The belt doesn't appear worn but i suppose it could be, or could the clutch being going out on me? I know on golf carts you can just replace the clutch spring far before you have to replace the whole assembly, is this the case with argos as well?
Thanks!
Thanks!
