Avenger Throttle Replacement
  • Avenger Throttle Replacement
    Hello guys,
    I was just wondering if it is normal with the forward play in the twist throttle? I just replaced the old as it was worn out and the new throttle has a lot of forward play. Any help would be greatly appreciated. Thanks.
    You shouldn't have a lot of forward play. You should be able to adjust that out using the adjustment screws on the cable either at the throttle or at the engine either one.
      Hi Mike, thanks for the info. I will try that and I will let you know.
        Hello Mike,
        I did it and its a lot better. There is still a little play though. Thanks.
