Hey,
I just finished changing a front drive chain as the previous one was loose. Figured while I had everything apart I would grease the spindle bearings and idler shaft bearings. Well even with the side grease gun fitting I had a hell of a time getting to the idler shaft bearings behind the brake disks......any tricks
? Changing the chain was easy. Other note does the front drive shaft sprocket have set screws in it or is it a floating sprocket?
Thanks LT
? Changing the chain was easy. Other note does the front drive shaft sprocket have set screws in it or is it a floating sprocket?Thanks LT
fbCoderson75
