Hi All,
I was doing the end of season servicing and changing the tranny fluid is of course part of that. So i warmed up the machine, pulled the plug to drain, then inserted the vacuum hose to make sure i got as much fluid as possible. Then i refilled it to the mid point on the indicator glass, as per the manual. It certainly did not take the 1.1l it was supposed to. Waited a bit and fired it up and ran it. The fluid level in the glass dropped to nothing while the machine was running (F-N-R for few minutes). Shut it off and then watched as fluid came back up in the glass...but now it is almost to the top of the glass, and it doesn't go down again.
Has anyone else experienced this? Do i drain some off? This is what, no. 4 or 5 fluid change; never noticed this before.
